Date/Time: Tue, 18 Feb 2025 22:07:01 +0000
Tools menu
View Count: 330
[2024-03-06 20:10:54] |
johnsierra - Posts: 4 |
A question relating to the tools in tool menu Here is an example of the problem I go to tools on my chart>> select horizontal line>> then place on drawing To edit this line >> right click >> chart drawing properties>> then a black box appears but does not seem to want to retain commands for the next time I use that tool ... But however here is the odd thing when I go to tools on the same chart>> and this time select extending rectangle place that on my drawing >> right click>> chart drawing properties>> I get a different box altogether this one is white in colour with a quick load menu and retains the command for next time I use it, How can I make this the default for my tools editing Many thanks John |
[2024-03-06 22:26:18] |
John - SC Support - Posts: 38029 |
The "Extending Rectangle" properties window is the old style. The black one that you see with the "Horizontal Line" is the new style that we are rolling out for the drawing tools. There have been multiple updates to this just the last few days, so make sure you are on the most recent release to ensure you have all the changes. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
