Date/Time: Mon, 25 Nov 2024 10:44:46 +0000
[User Discussion] - Draw line at the Alert
View Count: 205
[2024-03-06 20:03:41]
User744218 - Posts: 15
Greetings,
Is there a way to draw a line to show the price when an alert sounds (I use Renko's visual study)? The alert is on the Renko visual open/close study.
I see the alert goes on sometimes, but it does not other times, even though the criteria are met.
Thank you!
[2024-03-06 22:23:46]
We can not help with the alert not working all the time, that would mean there is something in your alert or setup that is not correct.
With regards to showing a line (although a line would actually not be visible - you should use some kind of marker item like a star or circle) when an alert is true, you would use the "Color Bar Based on Alert Condition" study to do this. Refer to the following, particularly the section on "Drawing Arrows/Text or Other Styles at the High or Low of Bars":
