Date/Time: Mon, 25 Nov 2024 06:46:19 +0000
Chart Dom Trading - Market buy & Market Sell possibiliy
View Count: 305
[2024-03-06 13:42:39] |
User230940 - Posts: 121 |
Hi, I am trading through the Chart Dom by clicking left and right Mouse button above or below the last Tick. I miss the possibility to execute Market buy and Market sell through this. I tried "sell stop" on right click above the last tick in sell colunm and "Buy stop" on right click below last Tick on the buy column. This failed because "Teton CME: Stop price must be above or below". Would it be possible to add the Market buy and Market Sell Option to the Chart DOM Trading? thanks |
[2024-03-20 16:32:21] |
Hi, is it possible to add? thanks |
[2024-03-20 17:38:29] |
There is not an option for this in the Chart DOM options. We can not say when we would get around to adding this option. Right now, however, you can use the right-mouse option to place a market order or use a Control Bar or Keyboard shortcut. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-20 18:51:04] |
Hi John, what do you mean by "right-mouse option to place a market order"? You means on the Chart and not on the DOM, right? I would like to have it on the DOM is: I want to use the same process to set an Order and any usecase and I set my order through right and left click on the DOM. Thanks |
[2024-03-20 22:15:42] |
Yes, we are referring to the Chart. We are just giving you some other options, as we do not know when we would be able to get to adding it to the Chart DOM options.
[2024-03-21 08:21:07] |
[2024-03-21 08:36:14] |
Sierra_Chart Engineering - Posts: 17172 |
This would never be added. It makes no sense. You can effectively do a market order simply by putting a buy Limit order in above the current price and a sell Limit order in below the current price.
[2024-03-21 08:53:38] |
But this Field (right click buy above & right click sell below) is settle already with an other Order Type. I will check the Shortscut Buy / sell market to integrate into my workflow. Maybe the best. thanks |
