Date/Time: Mon, 25 Nov 2024 11:35:21 +0000
Single Chart within Chartbook Does not Open
View Count: 195
[2024-03-06 12:23:27]
User276813 - Posts: 64
I have a one second chart in my book that does not open. It works, because I text display pointing to it.
But when I click on CW (main menu bar) - then select the chart, nothing happens. How do I get this chart to open / show on my screen?
[2024-03-06 18:25:19]
We assume the chart is detached, so select "Windows >> Reset Windows" and then see if you can get the window to show up. Refer to the following:
Window, CB and CW Menus: Reset Windows (Window)
If the chart is attached, then do you have your main view maximized so you are looking at one chart at a time, or are you viewing multiple charts and still not able to find it?
