Date/Time: Sun, 08 Sep 2024 03:11:55 +0000
Changing order quantity on DOM
View Count: 228
[2024-03-06 06:05:03] |
User480295 - Posts: 12 |
Hi, Can I suggest having the option of changing the order quantity on the right click of the mouse on the DOM? Trading Technologies has that function. For example, I can set 2 default order quantities like 2 and 1. When I left click, the order quantity is 2 and when I right click the order quantity is 1. This is useful when I just want to partially close my position in a fast paced market. Thanks lots to the awesome Sierra Chart people for creating such an awesome product. Truly appreciate you guys! |
[2024-03-12 14:37:11] |
Rui S - Posts: 180 |
User480295, To easily change the order quantity on the Trade DOM, with the DOM selected you just need to enter the number you want and press Enter. That's as simple as that. I hope this helps. |
[2024-07-08 18:58:05] |
Sierra_Chart Engineering - Posts: 16292 |
Yes this is true. Here is the documentation: Chart Trading and the Chart DOM: Changing Order Quantity on the Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
