Date/Time: Wed, 27 Nov 2024 06:37:43 +0000
Spreadsheet back test
View Count: 920
[2014-08-07 19:39:41] |
User14682 - Posts: 83 |
why cant I run a back test on a spreadsheet anymore?
[2014-08-08 00:37:36] |
What is the procedure that you are following? Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_Backtesting.php If you still have a problem what is the specific issue? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
