Date/Time: Sun, 24 Nov 2024 12:02:04 +0000
How to get in Spreadsheet the Swing High low values which are still active?
View Count: 270
[2024-03-05 23:27:15] |
artmaan - Posts: 23 |
i am trying to create a column in Spreadsheet to show me the values from the Swing high and low study which are still active on the chart. By active i mean, when "Extend Swings Until Future Intersection" is enabled i would like to see only the values from those lines and not all previous Swing high and lows. is there a smart way how to achieve this best? i would really appreciate if you could point me in the direction how to do it. i have also tried to modify the Swing high low study with the help of chatgpt, so it would output two more subgraphs with the needed values, but with no success yet ;). |
[2024-03-06 16:06:30] |
You can not do what you are asking using the built-in tools. The extension lines are special items that are not accessible through any of the tools. The only way to access the information is by creating a custom study (or modifying the existing study). Refer to the following: sc.GetStudyLineUntilFutureIntersection() List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-06 20:19:59] |
User273277 - Posts: 58 |
I am also looking to use the Extend Swings Until Future Intersection, but I just want to alert when price crosses any active line. Is this use case supported? |
[2024-06-06 21:19:48] |
The same situation applies here, the extension lines information is only available through a custom study. Refer to the links given previously.
