Date/Time: Mon, 25 Nov 2024 11:34:50 +0000
ES Issue with daily chart
View Count: 186
[2024-03-05 22:13:37] |
User447693 - Posts: 24 |
ES daily chart is missed dat from Feb 21st I just realized it. It only does it on ES daily even it is bar chart. NQ, MES, MNQ is all fine on the daily.
ChartImage.bmp - Attached On 2024-03-05 22:13:32 UTC - Size: 6.49 MB - 228 views |
[2024-03-05 22:14:09] |
Refer to the following: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data: 6.3: Missing Data in a Historical Chart Due to Missing Data in the Data File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
