Date/Time: Mon, 25 Nov 2024 12:39:03 +0000
Candle OHLC values at cursor position
View Count: 249
[2024-03-05 16:12:52] |
User763335 - Posts: 82 |
Hi Is there a way to see the candle's OHLC values printed at the top of chart(chart header)...of the candle where I'm placing the cursor on(or click on)? Right now, its showing the values of the current candle. thanks |
[2024-03-05 18:36:20] |
You need to use the "Tool Values Window" or the "Compact Tool Values Window" to view this information. Refer to the following: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-05 19:21:56] |
Thanks, found it and enabled the Compact Tool values window. However on one of the charts(screenshot attached), only Y & Date/time appears, remaining values dont show up. Not sure whats different about this chart. Also how do control what shows up up in the Chart header? thanks |
2024-03-05_14-15-06.png / V - Attached On 2024-03-05 19:21:46 UTC - Size: 30.27 KB - 66 views |
[2024-03-05 19:46:09] |
Issue with the displaying values in the compact tools window fixed..had one of the settings accidentally disabled. Also was able to customize chart header columns. |
[2024-03-05 21:22:33] |
Great.
