Date/Time: Mon, 25 Nov 2024 12:54:42 +0000
Text Display For Study - how to change color upon condition?
View Count: 458
[2024-03-05 15:50:44]
funbun - Posts: 90
Using it to display the %change of day.
trying to implement one color for positive, another color for negative with Auto-Coloring but it won't effectuate.
I also tried to use Color Bar Based On Alert Condition to target the study color with an alert script, also with no success.
Any ideas?
[2024-03-05 17:32:42]
User719512 - Posts: 264
There is a study in OFL Freemium that does this. See this post for more info: OrderFlow Labs Free Tools Available Now | Post: 373140
[2024-03-05 19:04:08]
There is not a built in way to do this, as the Text Display for Study is actually creating a drawing, and there is no way to change a drawing that is drawn from a custom study based on something occurring.
Besides the suggestion above, if you are even moderately comfortable with coding, you can modify the source code for the study to get what you want. The source code is in Studies3.cpp in the ACS_Source folder under your main Sierra Chart folder. Refer to the following:
How to Build an Advanced Custom Study from Source Code
