Date/Time: Mon, 25 Nov 2024 12:52:53 +0000
Overlaying a 5 Min Candlesticks chart 'Imbalance Blocks' study on a 5 min Numbers Bars!
View Count: 308
[2024-03-05 12:58:24]
J DIDDY - Posts: 128
Hi Support
I'm trying to Overlay a 5 Min Candlestick chart 'Imbalance Blocks' study ('Draw Diagonal Stacked Imbalance Blocks - Intrabar Option' by a Third Party seller) on a 5 min Numbers Bars chart with 'Study Overlay Bar'
The 5 min candle chart has the tick set to 3.000000, and the 5 min numbers bars chart has the default setting of 0.250000
(I'm doing this because the volume and imbalance blocks are much more potent when the tick is condensed to 3.000000, as opposed to the numbers bars version of the imbalance study - which I want to keep with the default tick setting so I can see other things!)
The study doesn't appear when I set this up though, so I'm wondering whether 3rd party studies are supported for Overlay and if so if you know what the issue may be??
I attach a pic for your reference.
Many thanks
Private File
[2024-03-05 13:48:21]
User431178 - Posts: 541
not support but...
Any study that stores (and displays) data by subgraph can be overlaid.
Does the other 3rd party dev use chart drawings to show the imbalance blocks?
Do they have an option to add as user drawn?
If so then you should be able to see the drawings on other charts using the native functionality - Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
