Date/Time: Mon, 25 Nov 2024 12:20:57 +0000
NASDAQ TotalView US stock" failed to load Depth of Market
View Count: 252
[2024-03-05 03:07:31] |
User561384 - Posts: 9 |
I am really getting annoyed by the fact that "NASDAQ TotalView US stock" failed to load Depth of Market if I load more than two stocks at a time. I have been using for futures and I didn't have any issues only having issues with "NASDAQ TotalView US stock". You need to look at this and fix the problem, I am paying around $40 for the platform and $16 for NASDAQ TotalView US stock. But I don't get the data properly , always issues then I have close the sierra chart and open only one stock at a time. |
[2024-03-05 04:00:50] |
Sierra_Chart Engineering - Posts: 17172 |
You are running a version of Sierra Chart that may not have proper support for NASDAQ TotalView market depth. You must update. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-05 04:02:21
