Date/Time: Mon, 25 Nov 2024 12:17:12 +0000
[User Discussion] - Spreadsheet question
View Count: 134
[2024-03-04 20:48:01]
User744218 - Posts: 15
Greetings.
I am not sure where I am going wrong.
1) I want a Buy open and Buy Close as shown in the picture but its not working. I read the documentation and forums and updated them, but still...
2) The intent is to open an order if the value is below 112 3.5/32 and Close at 112 14.5/32
3) AA3 is the value from a indicator
Thanks so much!
Date Time Of Last Edit: 2024-03-04 20:48:42
imagebuy limt SC.jpg / V - Attached On 2024-03-04 20:47:31 UTC - Size: 1.19 MB - 54 views
[2024-03-04 23:51:38]
Sawtooth - Posts: 4120
Signals are in columns K3-N3
Prices are in J22-J25
Order types are in J71-J74
Columns K-N are the signal columns and need a non-zero value at the bar/row where you want the signal, not in every row.
A TRUE signal must follow a FALSE signal.
Create a formula in Column O or higher, and then reverence it with another formula in K3 that goes TRUE when you want.
Where is price when the value is below 112 3.5/32 ?
If price is below the value, use a Buy Stop, if it's above the value, use a Buy Limit.
If it could be either, use a conditional IF statement in cell J71.
If you are entering/exiting a position intrabar, be sure to set 'Signal Only On Bar Close' to No.
If you have 'Signal Only Once Per Bar' set to Yes, be aware of this:
Spreadsheet Systems, Alerts and Automated Trading: Signal Only Once per Bar
