Date/Time: Mon, 25 Nov 2024 12:22:59 +0000
Flatten button
View Count: 437
[2024-03-04 19:28:47] |
User380262 - Posts: 3 |
Hi All, Since I have download the new sierra charts version I do not know a to change the flatten button settings. I am used to click on the flatten button when I want to close all order (limit/market). can you help please. Many thanks |
[2024-03-04 19:29:29] |
We do not understand your question. Nothing has changed with the Trade Window, so the Flatten button there is the same. Are you using a Flatten button setup differently?
[2024-03-04 19:55:08] |
Because I use attached orders I must click twice in order to close a market order. Nerve happened before. I have tried to look everywhere. Nothing relate to this setting
[2024-03-05 00:00:47] |
Are you using the Flatten button on the Trade Window, or are you using a Control Bar Button, or are you selecting the right-mouse option and then Flatten? Each of these is a bit different, in particular the "Flatten" button on the Trade Window is really a "Flatten and Cancel", so any attached orders will be closed out. But if you setup a Control Bar button for "Flatten" (and not "Flatten and Cancel") then that will only flatten the open position and will leave the working orders. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
