Date/Time: Wed, 27 Nov 2024 06:45:46 +0000
Getting Disconnected from Transact Server
View Count: 1378
[2014-08-07 15:41:34]
conr - Posts: 204
Hello, My charts keep getting disconnected.
TransAct Trading | Starting server: C:\SierraChart 1\Transact\TransactToSierraBridge.exe | 2014-08-07 10:35:30
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:35:32
Socket (1968) | Connected. | 2014-08-07 10:35:32
TransAct Trading | Connected to server. | 2014-08-07 10:35:32
TransAct Trading | Sending logon request message. | 2014-08-07 10:35:32
TransAct Trading | Market data feed reported to be lost. | 2014-08-07 10:36:00
TransAct Trading | Server Info - Server Name: Transact Futures/TransactToSierraBridge/1.3.2.0. | 2014-08-07 10:36:00
TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-07 10:36:00
TransAct Trading | Logon error from server : Communications Error | 2014-08-07 10:36:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:00
Socket (1968) | Shutdown and closed. | 2014-08-07 10:36:00
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:00
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:00
TransAct Trading | Bridge process is still running. | 2014-08-07 10:36:02
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:36:04
Socket (1148) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:36:05
Socket (1148) | Shutdown and closed. | 2014-08-07 10:36:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:05
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:05
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:05
TransAct Trading | Bridge process is still running. | 2014-08-07 10:36:07
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:36:09
Socket (1968) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:36:10
Socket (1968) | Shutdown and closed. | 2014-08-07 10:36:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:10
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:10
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:10
TransAct Trading | Bridge process is still running. | 2014-08-07 10:36:12
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:36:14
Socket (1148) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:36:15
Socket (1148) | Shutdown and closed. | 2014-08-07 10:36:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:15
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:15
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:15
TransAct Trading | Bridge process is still running. | 2014-08-07 10:36:17
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:36:19
Socket (1148) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:36:20
Socket (1148) | Shutdown and closed. | 2014-08-07 10:36:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:20
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:20
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:20
TransAct Trading | Starting server: C:\SierraChart 1\Transact\TransactToSierraBridge.exe | 2014-08-07 10:36:22
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:36:24
Socket (2372) | Connected. | 2014-08-07 10:36:24
TransAct Trading | Connected to server. | 2014-08-07 10:36:24
TransAct Trading | Sending logon request message. | 2014-08-07 10:36:24
TransAct Trading | Market data feed reported to be lost. | 2014-08-07 10:36:47
TransAct Trading | Server Info - Server Name: Transact Futures/TransactToSierraBridge/1.3.2.0. | 2014-08-07 10:36:47
TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-07 10:36:47
TransAct Trading | Logon error from server : Communications Error | 2014-08-07 10:36:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:47
Socket (2372) | Shutdown and closed. | 2014-08-07 10:36:47
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:47
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:47
TransAct Trading | Bridge process is still running. | 2014-08-07 10:36:49
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:36:51
Socket (944) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:36:52
Socket (944) | Shutdown and closed. | 2014-08-07 10:36:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:52
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:52
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:52
TransAct Trading | Bridge process is still running. | 2014-08-07 10:36:54
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:36:56
Socket (900) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:36:57
Socket (900) | Shutdown and closed. | 2014-08-07 10:36:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:36:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:36:57
TransAct Trading | Disconnected from the server. | 2014-08-07 10:36:57
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:36:57
TransAct Trading | Bridge process is still running. | 2014-08-07 10:36:59
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:37:01
Socket (944) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:37:02
Socket (944) | Shutdown and closed. | 2014-08-07 10:37:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:37:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:37:02
TransAct Trading | Disconnected from the server. | 2014-08-07 10:37:02
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:37:02
TransAct Trading | Bridge process is still running. | 2014-08-07 10:37:04
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:37:07
Socket (900) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:37:08
Socket (900) | Shutdown and closed. | 2014-08-07 10:37:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:37:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:37:08
TransAct Trading | Disconnected from the server. | 2014-08-07 10:37:08
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:37:08
TransAct Trading | Bridge process is still running. | 2014-08-07 10:37:10
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:37:12
Socket (944) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:37:13
Socket (944) | Shutdown and closed. | 2014-08-07 10:37:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:37:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:37:13
TransAct Trading | Disconnected from the server. | 2014-08-07 10:37:13
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:37:13
TransAct Trading | Bridge process is still running. | 2014-08-07 10:37:15
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:37:17
Socket (900) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 10:37:18
Socket (900) | Shutdown and closed. | 2014-08-07 10:37:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:37:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:37:18
TransAct Trading | Disconnected from the server. | 2014-08-07 10:37:18
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:37:18
TransAct Trading | Starting server: C:\SierraChart 1\Transact\TransactToSierraBridge.exe | 2014-08-07 10:37:20
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:37:22
Socket (668) | Connected. | 2014-08-07 10:37:22
TransAct Trading | Connected to server. | 2014-08-07 10:37:22
TransAct Trading | Sending logon request message. | 2014-08-07 10:37:22
TransAct Trading | Market data feed reported to be lost. | 2014-08-07 10:37:45
TransAct Trading | Server Info - Server Name: Transact Futures/TransactToSierraBridge/1.3.2.0. | 2014-08-07 10:37:45
TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-07 10:37:45
TransAct Trading | Logon error from server : Communications Error | 2014-08-07 10:37:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:37:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:37:45
Socket (668) | Shutdown and closed. | 2014-08-07 10:37:45
TransAct Trading | Disconnected from the server. | 2014-08-07 10:37:45
Will reconnect to the server in 35.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:37:45
TransAct Trading | Starting server: C:\SierraChart 1\Transact\TransactToSierraBridge.exe | 2014-08-07 10:38:20
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:38:22
Socket (1968) | Connected. | 2014-08-07 10:38:22
TransAct Trading | Connected to server. | 2014-08-07 10:38:22
TransAct Trading | Sending logon request message. | 2014-08-07 10:38:22
TransAct Trading | Market data feed reported to be lost. | 2014-08-07 10:38:45
TransAct Trading | Server Info - Server Name: Transact Futures/TransactToSierraBridge/1.3.2.0. | 2014-08-07 10:38:45
TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-07 10:38:45
TransAct Trading | Logon error from server : Communications Error | 2014-08-07 10:38:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:38:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:38:45
Socket (1968) | Shutdown and closed. | 2014-08-07 10:38:45
TransAct Trading | Disconnected from the server. | 2014-08-07 10:38:45
Will reconnect to the server in 40.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:38:45
TransAct Trading | Starting server: C:\SierraChart 1\Transact\TransactToSierraBridge.exe | 2014-08-07 10:39:25
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:39:27
Socket (668) | Connected. | 2014-08-07 10:39:27
TransAct Trading | Connected to server. | 2014-08-07 10:39:27
TransAct Trading | Sending logon request message. | 2014-08-07 10:39:27
TransAct Trading | Market data feed reported to be lost. | 2014-08-07 10:39:52
TransAct Trading | Server Info - Server Name: Transact Futures/TransactToSierraBridge/1.3.2.0. | 2014-08-07 10:39:52
TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-07 10:39:52
TransAct Trading | Logon error from server : Communications Error | 2014-08-07 10:39:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:39:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:39:52
Socket (668) | Shutdown and closed. | 2014-08-07 10:39:52
TransAct Trading | Disconnected from the server. | 2014-08-07 10:39:52
Will reconnect to the server in 40.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:39:52
TransAct Trading | Starting server: C:\SierraChart 1\Transact\TransactToSierraBridge.exe | 2014-08-07 10:40:32
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-08-07 10:40:34
Socket (1108) | Connected. | 2014-08-07 10:40:34
TransAct Trading | Connected to server. | 2014-08-07 10:40:34
TransAct Trading | Sending logon request message. | 2014-08-07 10:40:34
TransAct Trading | Market data feed reported to be lost. | 2014-08-07 10:41:09
TransAct Trading | Server Info - Server Name: Transact Futures/TransactToSierraBridge/1.3.2.0. | 2014-08-07 10:41:09
TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-07 10:41:09
TransAct Trading | Logon error from server : Communications Error | 2014-08-07 10:41:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 10:41:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 10:41:09
Socket (1108) | Shutdown and closed. | 2014-08-07 10:41:09
TransAct Trading | Disconnected from the server. | 2014-08-07 10:41:09
Will reconnect to the server in 45.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 10:41:09
[2014-08-07 16:36:50]
This is a TransAct connection error. TransAct support will need to help you with this.
