Date/Time: Mon, 25 Nov 2024 12:22:43 +0000
Overlaying a 20 sec Cum Delta Bars Candlesticks study on a 5 min Numbers Bars!
View Count: 310
[2024-03-04 12:40:57] |
J DIDDY - Posts: 128 |
HI Support I want to Overlay a 20 sec chart 'Cum Delta bars - volume' study (Candlesticks) in Chart position 1 to Chart position 1 of a 5 min Numbers Bars study...Is this possible?? I tried using the Study Overlay Bars, but it doesn't seem to work.... Maybe I cant mix candlesticks with Numbers bars??? Is there a way around this?? I've attached a pic of the Bars from the 20s chart (Red circle) I want to overlay onto the 5 min Numbers bars.... Please advise Thx |
Private File |
[2024-03-04 16:54:13] |
You can overlay bars to the Numbers Bars, but you have to be careful on how you do this. But, the real problem you are having is that you are trying to overlay bars with values in the hundreds to a chart with prices at 18000. To do this, you would need to set the Study/Price Overlay scaling to be "Independent". But we do not think you will like result. It is best to keep the Cumulative Delta Bars in a different region. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-04 17:03:03] |
OK, I'll try it and see... Many thanks |
