Date/Time: Mon, 25 Nov 2024 12:36:30 +0000
dual study crosshair / hand
View Count: 185
[2024-03-04 08:34:08] |
SafSaf - Posts: 89 |
hello team, is there a way that i can set my hand tool so when i hover it over the main chart it also appears in the same place on a study in another chart region, say region two.
[2024-03-04 16:13:48] |
When using the Crosshairs (in whatever mode you are using and have them on) they will show across all regions. So we are not quite sure what exactly is not working for you. Please give us more information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-04 19:10:38] |
to be more specific; if we had a chart open which had the top half as a price chart and the bottom half as a cumulative delta chart (for example), at present the vertical line of the crosshair shows on both panels. i'd like the horizontal line of the crosshair to also show on the cumulative delta chart beneath. does that make more sense?
[2024-03-04 21:19:11] |
There is not an option for this.
