Date/Time: Wed, 27 Nov 2024 06:41:21 +0000
unable to connect
View Count: 1235
[2014-08-07 03:44:00]
User53196 - Posts: 13
i simply cannot connect. it tries but no cigar
[2014-08-07 04:26:34]
We see you are using Interactive Brokers. Refer to step 22 here about this:
http://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions
[2014-08-07 12:08:33]
All the setting were still in place as per your instructions. the log imply says attempting to connect in 5 seconds over and over. I have closed app and reopened. simply in a loop
[2014-08-07 16:16:12]
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2014-08-07 17:13:29]
Software version: 1154 | 2014-08-07 11:02:40
Usage end date: 2014-08-16 | 2014-08-07 11:02:40
Enabled for: Advanced Features. | 2014-08-07 11:02:40
Enabled for: Advanced Features 2. | 2014-08-07 11:02:40
Enabled for: Sierra Chart Historical Data Service. | 2014-08-07 11:02:40
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-07 11:02:40
Active service: myTrack | 2014-08-07 11:02:40
Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-07 11:02:40
2014-08-07 11:02:40 Local computer clock time | 2014-08-07 11:02:40
2014-08-07 17:02:40 GMT time | 2014-08-07 11:02:40
2014-08-07 11:02:40 Time zone adjusted time | 2014-08-07 11:02:40
Time difference to server time: 1 seconds. | 2014-08-07 11:02:40
Program path: C:\SierraChart\ | 2014-08-07 11:02:40
Data Files path: C:\SierraChart\Data\ | 2014-08-07 11:02:40
OS Version Number: 6.1 | 2014-08-07 11:02:40
Checking for new symbol settings for mt | 2014-08-07 11:02:40
Symbol settings are up-to-date for mt | 2014-08-07 11:02:41
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:02:45
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:02:45
Socket (1996) - Connected. | 2014-08-07 11:02:46
Waiting for acceptance... | 2014-08-07 11:02:46
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:02:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:02:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:02:46
Socket (1996) - Shutdown and closed. | 2014-08-07 11:02:46
Disconnected from MyTrack. | 2014-08-07 11:02:46
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:02:46
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:02:51
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:02:51
Socket (2000) - Connected. | 2014-08-07 11:02:51
Waiting for acceptance... | 2014-08-07 11:02:51
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:02:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:02:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:02:51
Socket (2000) - Shutdown and closed. | 2014-08-07 11:02:51
Disconnected from MyTrack. | 2014-08-07 11:02:51
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:02:51
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:02:56
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:02:56
Socket (1996) - Connected. | 2014-08-07 11:02:56
Waiting for acceptance... | 2014-08-07 11:02:56
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:02:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:02:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:02:56
Socket (1996) - Shutdown and closed. | 2014-08-07 11:02:56
Disconnected from MyTrack. | 2014-08-07 11:02:56
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:02:56
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:01
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:01
Socket (2000) - Connected. | 2014-08-07 11:03:01
Waiting for acceptance... | 2014-08-07 11:03:01
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:03:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:01
Socket (2000) - Shutdown and closed. | 2014-08-07 11:03:01
Disconnected from MyTrack. | 2014-08-07 11:03:01
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:01
Socket (1996) - Connected. | 2014-08-07 11:03:01
Socket (1996) - Shutdown and closed. | 2014-08-07 11:03:01
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:06
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:06
Socket (2000) - Connected. | 2014-08-07 11:03:07
Waiting for acceptance... | 2014-08-07 11:03:07
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:03:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:07
Socket (2000) - Shutdown and closed. | 2014-08-07 11:03:07
Disconnected from MyTrack. | 2014-08-07 11:03:07
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:07
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:12
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:12
Socket (1956) - Connected. | 2014-08-07 11:03:12
Waiting for acceptance... | 2014-08-07 11:03:12
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:03:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:12
Socket (1956) - Shutdown and closed. | 2014-08-07 11:03:12
Disconnected from MyTrack. | 2014-08-07 11:03:12
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:12
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:17
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:17
Socket (1960) - Connected. | 2014-08-07 11:03:17
Waiting for acceptance... | 2014-08-07 11:03:17
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:03:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:17
Socket (1960) - Shutdown and closed. | 2014-08-07 11:03:17
Disconnected from MyTrack. | 2014-08-07 11:03:17
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:17
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:22
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:22
Socket (1956) - Connected. | 2014-08-07 11:03:22
Waiting for acceptance... | 2014-08-07 11:03:22
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:03:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:22
Socket (1956) - Shutdown and closed. | 2014-08-07 11:03:22
Disconnected from MyTrack. | 2014-08-07 11:03:22
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:22
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:27
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:27
Socket (1960) - Connected. | 2014-08-07 11:03:27
Waiting for acceptance... | 2014-08-07 11:03:27
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:03:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:27
Socket (1960) - Shutdown and closed. | 2014-08-07 11:03:27
Disconnected from MyTrack. | 2014-08-07 11:03:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:27
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:32
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:32
Socket (1956) - Connected. | 2014-08-07 11:03:32
Waiting for acceptance... | 2014-08-07 11:03:32
Error from MyTrack: Too many login attempts. | 2014-08-07 11:03:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:32
Socket (1956) - Shutdown and closed. | 2014-08-07 11:03:32
Disconnected from MyTrack. | 2014-08-07 11:03:32
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:32
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:38
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:38
Socket (484) - Connected. | 2014-08-07 11:03:38
Waiting for acceptance... | 2014-08-07 11:03:38
Error from MyTrack: Too many login attempts. | 2014-08-07 11:03:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:38
Socket (484) - Shutdown and closed. | 2014-08-07 11:03:38
Disconnected from MyTrack. | 2014-08-07 11:03:38
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:38
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:43
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:43
Socket (1972) - Connected. | 2014-08-07 11:03:43
Waiting for acceptance... | 2014-08-07 11:03:43
Error from MyTrack: Too many login attempts. | 2014-08-07 11:03:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:43
Socket (1972) - Shutdown and closed. | 2014-08-07 11:03:43
Disconnected from MyTrack. | 2014-08-07 11:03:43
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:43
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:48
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:48
Socket (1212) - Connected. | 2014-08-07 11:03:48
Waiting for acceptance... | 2014-08-07 11:03:48
Error from MyTrack: Too many login attempts. | 2014-08-07 11:03:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:48
Socket (1212) - Shutdown and closed. | 2014-08-07 11:03:48
Disconnected from MyTrack. | 2014-08-07 11:03:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:48
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:53
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:53
Socket (1216) - Connected. | 2014-08-07 11:03:53
Waiting for acceptance... | 2014-08-07 11:03:53
Error from MyTrack: Too many login attempts. | 2014-08-07 11:03:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:53
Socket (1216) - Shutdown and closed. | 2014-08-07 11:03:53
Disconnected from MyTrack. | 2014-08-07 11:03:53
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:53
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:03:58
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:03:58
Socket (1212) - Connected. | 2014-08-07 11:03:58
Waiting for acceptance... | 2014-08-07 11:03:58
Error from MyTrack: Too many login attempts. | 2014-08-07 11:03:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:03:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:03:58
Socket (1212) - Shutdown and closed. | 2014-08-07 11:03:58
Disconnected from MyTrack. | 2014-08-07 11:03:58
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:03:58
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:03
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:03
Socket (1216) - Connected. | 2014-08-07 11:04:04
Waiting for acceptance... | 2014-08-07 11:04:04
Error from MyTrack: Too many login attempts. | 2014-08-07 11:04:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:04
Socket (1216) - Shutdown and closed. | 2014-08-07 11:04:04
Disconnected from MyTrack. | 2014-08-07 11:04:04
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:04
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:09
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:09
Socket (1212) - Connected. | 2014-08-07 11:04:09
Waiting for acceptance... | 2014-08-07 11:04:09
Error from MyTrack: Too many login attempts. | 2014-08-07 11:04:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:09
Socket (1212) - Shutdown and closed. | 2014-08-07 11:04:09
Disconnected from MyTrack. | 2014-08-07 11:04:09
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:09
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:14
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:14
Socket (1216) - Connected. | 2014-08-07 11:04:14
Waiting for acceptance... | 2014-08-07 11:04:14
Error from MyTrack: Too many login attempts. | 2014-08-07 11:04:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:14
Socket (1216) - Shutdown and closed. | 2014-08-07 11:04:14
Disconnected from MyTrack. | 2014-08-07 11:04:14
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:14
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:19
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:19
Socket (1212) - Connected. | 2014-08-07 11:04:19
Waiting for acceptance... | 2014-08-07 11:04:19
Error from MyTrack: Too many login attempts. | 2014-08-07 11:04:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:19
Socket (1212) - Shutdown and closed. | 2014-08-07 11:04:19
Disconnected from MyTrack. | 2014-08-07 11:04:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:19
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:24
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:24
Socket (968) - Connected. | 2014-08-07 11:04:24
Waiting for acceptance... | 2014-08-07 11:04:24
Error from MyTrack: Too many login attempts. | 2014-08-07 11:04:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:24
Socket (968) - Shutdown and closed. | 2014-08-07 11:04:24
Disconnected from MyTrack. | 2014-08-07 11:04:24
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:24
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:29
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:29
Socket (968) - Connected. | 2014-08-07 11:04:29
Waiting for acceptance... | 2014-08-07 11:04:29
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:04:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:29
Socket (968) - Shutdown and closed. | 2014-08-07 11:04:29
Disconnected from MyTrack. | 2014-08-07 11:04:29
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:29
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:35
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:35
Socket (972) - Connected. | 2014-08-07 11:04:35
Waiting for acceptance... | 2014-08-07 11:04:35
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:04:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:35
Socket (972) - Shutdown and closed. | 2014-08-07 11:04:35
Disconnected from MyTrack. | 2014-08-07 11:04:35
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:35
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:40
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:40
Socket (1240) - Connected. | 2014-08-07 11:04:40
Waiting for acceptance... | 2014-08-07 11:04:40
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:04:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:40
Socket (1240) - Shutdown and closed. | 2014-08-07 11:04:40
Disconnected from MyTrack. | 2014-08-07 11:04:40
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:40
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:45
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:45
Socket (1264) - Connected. | 2014-08-07 11:04:45
Waiting for acceptance... | 2014-08-07 11:04:45
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:04:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:45
Socket (1264) - Shutdown and closed. | 2014-08-07 11:04:45
Disconnected from MyTrack. | 2014-08-07 11:04:45
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:45
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:50
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:50
Socket (1256) - Connected. | 2014-08-07 11:04:50
Waiting for acceptance... | 2014-08-07 11:04:50
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:04:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:50
Socket (1256) - Shutdown and closed. | 2014-08-07 11:04:50
Disconnected from MyTrack. | 2014-08-07 11:04:50
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:50
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:04:55
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:04:55
Socket (1264) - Connected. | 2014-08-07 11:04:55
Waiting for acceptance... | 2014-08-07 11:04:55
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:04:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:04:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:04:55
Socket (1264) - Shutdown and closed. | 2014-08-07 11:04:55
Disconnected from MyTrack. | 2014-08-07 11:04:55
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:04:55
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:05:00
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:05:00
Socket (1256) - Connected. | 2014-08-07 11:05:00
Waiting for acceptance... | 2014-08-07 11:05:00
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:05:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:05:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:05:01
Socket (1256) - Shutdown and closed. | 2014-08-07 11:05:01
Disconnected from MyTrack. | 2014-08-07 11:05:01
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:05:01
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:05:06
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:05:06
Socket (1256) - Connected. | 2014-08-07 11:05:06
Waiting for acceptance... | 2014-08-07 11:05:06
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:05:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:05:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:05:06
Socket (1256) - Shutdown and closed. | 2014-08-07 11:05:06
Disconnected from MyTrack. | 2014-08-07 11:05:06
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:05:06
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:05:11
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:05:11
Socket (968) - Connected. | 2014-08-07 11:05:11
Waiting for acceptance... | 2014-08-07 11:05:11
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:05:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:05:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:05:11
Socket (968) - Shutdown and closed. | 2014-08-07 11:05:11
Disconnected from MyTrack. | 2014-08-07 11:05:11
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:05:11
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:08:11
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:08:11
Socket (2000) - Connected. | 2014-08-07 11:08:11
Waiting for acceptance... | 2014-08-07 11:08:11
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:08:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:08:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:08:11
Socket (2000) - Shutdown and closed. | 2014-08-07 11:08:11
Disconnected from MyTrack. | 2014-08-07 11:08:11
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:08:11
Connecting to data feed server host.trackdata.com port 9983... | 2014-08-07 11:11:11
Socket (0) - Resolved address host.trackdata.com to IP 198.6.17.31 | 2014-08-07 11:11:11
Socket (1080) - Connected. | 2014-08-07 11:11:11
Waiting for acceptance... | 2014-08-07 11:11:11
Error from MyTrack: Invalid MyTrack username or password. Select File >> Data/Trade Service Settings on the menu to set them. | 2014-08-07 11:11:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 11:11:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 11:11:11
Socket (1080) - Shutdown and closed. | 2014-08-07 11:11:11
Disconnected from MyTrack. | 2014-08-07 11:11:11
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 11:11:11
[2014-08-07 17:31:04]
What Data or Trading service do you want to use? Interactive Brokers?
[2014-08-07 18:00:37]
yes, interactive brokers
[2014-08-07 18:06:32]
You have the wrong service selected in Sierra Chart.
Select Global Settings >> Data/Trade Service Settings.
At the top, set the "Service" to Interactive Brokers.
Press OK.
Select File >> Connect to Data Feed.
[2014-08-07 22:20:31]
followed all the directions to the letter. closed all applications and rebooted. same thing. is there any way to restore original setting or something?
[2014-08-07 22:23:17]
Now that you have changed the Service to Interactive Brokers we need to see the Message Log again.
Date Time Of Last Edit: 2014-08-07 22:23:28
[2014-08-07 22:26:12]
Software version: 1154 | 2014-08-07 16:07:12
Usage end date: 2014-08-16 | 2014-08-07 16:07:12
Enabled for: Advanced Features. | 2014-08-07 16:07:12
Enabled for: Advanced Features 2. | 2014-08-07 16:07:12
Enabled for: Sierra Chart Historical Data Service. | 2014-08-07 16:07:12
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-07 16:07:12
Active service: Interactive Brokers | 2014-08-07 16:07:12
Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-07 16:07:12
2014-08-07 16:07:12 Local computer clock time | 2014-08-07 16:07:12
2014-08-07 22:07:12 GMT time | 2014-08-07 16:07:12
2014-08-07 16:07:12 Time zone adjusted time | 2014-08-07 16:07:12
Time difference to server time: 1 seconds. | 2014-08-07 16:07:12
Program path: C:\SierraChart\ | 2014-08-07 16:07:12
Data Files path: C:\SierraChart\Data\ | 2014-08-07 16:07:12
OS Version Number: 6.1 | 2014-08-07 16:07:12
Checking for new symbol settings for ib | 2014-08-07 16:07:12
Symbol settings are up-to-date for ib | 2014-08-07 16:07:12
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:07:17
Socket (1992) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:07:18
Socket (1992) - Shutdown and closed. | 2014-08-07 16:07:18
Failed to connect to the data and trade server. | 2014-08-07 16:07:18
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:07:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:07:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:07:18
Disconnected from IB. | 2014-08-07 16:07:18
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:07:18
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:07:23
Socket (1984) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:07:24
Socket (1984) - Shutdown and closed. | 2014-08-07 16:07:24
Failed to connect to the data and trade server. | 2014-08-07 16:07:24
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:07:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:07:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:07:24
Disconnected from IB. | 2014-08-07 16:07:24
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:07:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:07:29
Socket (1992) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:07:30
Socket (1992) - Shutdown and closed. | 2014-08-07 16:07:30
Failed to connect to the data and trade server. | 2014-08-07 16:07:30
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:07:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:07:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:07:30
Disconnected from IB. | 2014-08-07 16:07:30
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:07:30
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:07:35
Socket (1984) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:07:36
Socket (1984) - Shutdown and closed. | 2014-08-07 16:07:36
Failed to connect to the data and trade server. | 2014-08-07 16:07:36
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:07:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:07:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:07:36
Disconnected from IB. | 2014-08-07 16:07:36
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:07:36
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:07:41
Socket (1992) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:07:42
Socket (1992) - Shutdown and closed. | 2014-08-07 16:07:42
Failed to connect to the data and trade server. | 2014-08-07 16:07:42
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:07:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:07:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:07:42
Disconnected from IB. | 2014-08-07 16:07:42
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:07:42
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:07:47
Socket (1976) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:07:48
Socket (1976) - Shutdown and closed. | 2014-08-07 16:07:48
Failed to connect to the data and trade server. | 2014-08-07 16:07:48
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:07:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:07:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:07:48
Disconnected from IB. | 2014-08-07 16:07:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:07:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:07:53
Current selected Data/Trading service: Interactive Brokers | 2014-08-07 16:07:54
Socket (1980) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:07:55
Socket (1980) - Shutdown and closed. | 2014-08-07 16:07:55
Failed to connect to the data and trade server. | 2014-08-07 16:07:55
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:07:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:07:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:07:55
Disconnected from IB. | 2014-08-07 16:07:55
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:07:55
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:00
Socket (1976) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:01
Socket (1976) - Shutdown and closed. | 2014-08-07 16:08:01
Failed to connect to the data and trade server. | 2014-08-07 16:08:01
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:01
Disconnected from IB. | 2014-08-07 16:08:01
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:01
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:06
Socket (1980) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:07
Socket (1980) - Shutdown and closed. | 2014-08-07 16:08:07
Failed to connect to the data and trade server. | 2014-08-07 16:08:07
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:07
Disconnected from IB. | 2014-08-07 16:08:07
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:07
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:12
Socket (1060) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:13
Socket (1060) - Shutdown and closed. | 2014-08-07 16:08:13
Failed to connect to the data and trade server. | 2014-08-07 16:08:13
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:13
Disconnected from IB. | 2014-08-07 16:08:13
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:13
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:18
Socket (1996) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:19
Socket (1996) - Shutdown and closed. | 2014-08-07 16:08:19
Failed to connect to the data and trade server. | 2014-08-07 16:08:19
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:19
Disconnected from IB. | 2014-08-07 16:08:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:19
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:24
Socket (1208) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:25
Socket (1208) - Shutdown and closed. | 2014-08-07 16:08:25
Failed to connect to the data and trade server. | 2014-08-07 16:08:25
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:25
Disconnected from IB. | 2014-08-07 16:08:25
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:25
Current selected Data/Trading service: Interactive Brokers | 2014-08-07 16:08:25
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:30
Socket (1208) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:31
Socket (1208) - Shutdown and closed. | 2014-08-07 16:08:31
Failed to connect to the data and trade server. | 2014-08-07 16:08:31
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:31
Disconnected from IB. | 2014-08-07 16:08:31
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:31
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:36
Socket (1216) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:37
Socket (1216) - Shutdown and closed. | 2014-08-07 16:08:37
Failed to connect to the data and trade server. | 2014-08-07 16:08:37
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:37
Disconnected from IB. | 2014-08-07 16:08:37
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:37
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:42
Socket (1208) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:43
Socket (1208) - Shutdown and closed. | 2014-08-07 16:08:43
Failed to connect to the data and trade server. | 2014-08-07 16:08:43
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:43
Disconnected from IB. | 2014-08-07 16:08:43
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:43
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:48
Socket (1216) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:49
Socket (1216) - Shutdown and closed. | 2014-08-07 16:08:49
Failed to connect to the data and trade server. | 2014-08-07 16:08:49
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:49
Disconnected from IB. | 2014-08-07 16:08:49
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:49
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:08:54
Socket (1208) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:08:55
Socket (1208) - Shutdown and closed. | 2014-08-07 16:08:55
Failed to connect to the data and trade server. | 2014-08-07 16:08:55
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:08:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:08:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:08:55
Disconnected from IB. | 2014-08-07 16:08:55
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:08:55
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:00
Socket (1216) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:01
Socket (1216) - Shutdown and closed. | 2014-08-07 16:09:01
Failed to connect to the data and trade server. | 2014-08-07 16:09:01
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:01
Disconnected from IB. | 2014-08-07 16:09:01
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:01
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:06
Socket (1208) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:07
Socket (1208) - Shutdown and closed. | 2014-08-07 16:09:07
Failed to connect to the data and trade server. | 2014-08-07 16:09:07
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:07
Disconnected from IB. | 2014-08-07 16:09:07
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:07
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:12
Socket (1156) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:13
Socket (1156) - Shutdown and closed. | 2014-08-07 16:09:13
Failed to connect to the data and trade server. | 2014-08-07 16:09:13
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:13
Disconnected from IB. | 2014-08-07 16:09:13
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:13
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:18
Socket (1168) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:19
Socket (1168) - Shutdown and closed. | 2014-08-07 16:09:19
Failed to connect to the data and trade server. | 2014-08-07 16:09:19
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:19
Disconnected from IB. | 2014-08-07 16:09:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:19
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:24
Socket (1156) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:25
Socket (1156) - Shutdown and closed. | 2014-08-07 16:09:25
Failed to connect to the data and trade server. | 2014-08-07 16:09:25
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:25
Disconnected from IB. | 2014-08-07 16:09:25
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:25
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:30
Socket (1168) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:31
Socket (1168) - Shutdown and closed. | 2014-08-07 16:09:31
Failed to connect to the data and trade server. | 2014-08-07 16:09:31
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:31
Disconnected from IB. | 2014-08-07 16:09:32
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:32
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:37
Socket (1156) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:38
Socket (1156) - Shutdown and closed. | 2014-08-07 16:09:38
Failed to connect to the data and trade server. | 2014-08-07 16:09:38
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:38
Disconnected from IB. | 2014-08-07 16:09:38
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:38
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:43
Socket (1036) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:44
Socket (1036) - Shutdown and closed. | 2014-08-07 16:09:44
Failed to connect to the data and trade server. | 2014-08-07 16:09:44
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:44
Disconnected from IB. | 2014-08-07 16:09:44
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:49
Socket (944) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:50
Socket (944) - Shutdown and closed. | 2014-08-07 16:09:50
Failed to connect to the data and trade server. | 2014-08-07 16:09:50
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:50
Disconnected from IB. | 2014-08-07 16:09:50
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:50
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:09:55
Socket (1036) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:09:56
Socket (1036) - Shutdown and closed. | 2014-08-07 16:09:56
Failed to connect to the data and trade server. | 2014-08-07 16:09:56
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:09:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:09:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:09:56
Disconnected from IB. | 2014-08-07 16:09:56
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:09:56
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:10:01
Socket (944) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:10:02
Socket (944) - Shutdown and closed. | 2014-08-07 16:10:02
Failed to connect to the data and trade server. | 2014-08-07 16:10:02
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:10:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:10:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:10:02
Disconnected from IB. | 2014-08-07 16:10:02
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:10:02
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:10:07
Socket (1036) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:10:08
Socket (1036) - Shutdown and closed. | 2014-08-07 16:10:08
Failed to connect to the data and trade server. | 2014-08-07 16:10:08
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:10:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:10:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:10:08
Disconnected from IB. | 2014-08-07 16:10:08
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:10:08
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:10:13
Socket (944) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:10:14
Socket (944) - Shutdown and closed. | 2014-08-07 16:10:14
Failed to connect to the data and trade server. | 2014-08-07 16:10:14
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:10:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:10:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:10:14
Disconnected from IB. | 2014-08-07 16:10:14
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:10:14
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:13:14
Socket (1292) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:13:15
Socket (1292) - Shutdown and closed. | 2014-08-07 16:13:15
Failed to connect to the data and trade server. | 2014-08-07 16:13:15
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:13:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:13:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:13:15
Disconnected from IB. | 2014-08-07 16:13:15
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:13:15
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:16:15
Socket (684) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:16:16
Socket (684) - Shutdown and closed. | 2014-08-07 16:16:16
Failed to connect to the data and trade server. | 2014-08-07 16:16:16
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:16:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:16:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:16:16
Disconnected from IB. | 2014-08-07 16:16:16
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:16:16
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:19:16
Socket (1036) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:19:17
Socket (1036) - Shutdown and closed. | 2014-08-07 16:19:17
Failed to connect to the data and trade server. | 2014-08-07 16:19:17
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:19:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:19:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:19:17
Disconnected from IB. | 2014-08-07 16:19:17
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:19:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:22:17
Socket (1288) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:22:18
Socket (1288) - Shutdown and closed. | 2014-08-07 16:22:18
Failed to connect to the data and trade server. | 2014-08-07 16:22:18
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:22:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:22:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:22:18
Disconnected from IB. | 2014-08-07 16:22:18
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:22:18
Current selected Data/Trading service: Interactive Brokers | 2014-08-07 16:23:20
File >> Disconnect selected. | 2014-08-07 16:23:26
Disconnected from IB. | 2014-08-07 16:23:26
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:23:28
Socket (1464) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:23:30
Socket (1464) - Shutdown and closed. | 2014-08-07 16:23:30
Failed to connect to the data and trade server. | 2014-08-07 16:23:30
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:23:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:23:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:23:30
Disconnected from IB. | 2014-08-07 16:23:30
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:23:30
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:23:35
Socket (1260) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:23:36
Socket (1260) - Shutdown and closed. | 2014-08-07 16:23:36
Failed to connect to the data and trade server. | 2014-08-07 16:23:36
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:23:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:23:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:23:36
Disconnected from IB. | 2014-08-07 16:23:36
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:23:36
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:23:41
Socket (1464) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:23:42
Socket (1464) - Shutdown and closed. | 2014-08-07 16:23:42
Failed to connect to the data and trade server. | 2014-08-07 16:23:42
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:23:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:23:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:23:42
Disconnected from IB. | 2014-08-07 16:23:42
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:23:42
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:23:47
Socket (952) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:23:48
Socket (952) - Shutdown and closed. | 2014-08-07 16:23:48
Failed to connect to the data and trade server. | 2014-08-07 16:23:48
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:23:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:23:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:23:48
Disconnected from IB. | 2014-08-07 16:23:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:23:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:23:53
Socket (1292) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:23:54
Socket (1292) - Shutdown and closed. | 2014-08-07 16:23:54
Failed to connect to the data and trade server. | 2014-08-07 16:23:54
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:23:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:23:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:23:54
Disconnected from IB. | 2014-08-07 16:23:54
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:23:54
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:23:59
Socket (952) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:00
Socket (952) - Shutdown and closed. | 2014-08-07 16:24:00
Failed to connect to the data and trade server. | 2014-08-07 16:24:00
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:00
Disconnected from IB. | 2014-08-07 16:24:00
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:00
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:05
Socket (1292) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:06
Socket (1292) - Shutdown and closed. | 2014-08-07 16:24:06
Failed to connect to the data and trade server. | 2014-08-07 16:24:06
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:06
Disconnected from IB. | 2014-08-07 16:24:06
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:06
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:11
Socket (952) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:12
Socket (952) - Shutdown and closed. | 2014-08-07 16:24:12
Failed to connect to the data and trade server. | 2014-08-07 16:24:12
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:12
Disconnected from IB. | 2014-08-07 16:24:12
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:12
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:17
Socket (1292) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:18
Socket (1292) - Shutdown and closed. | 2014-08-07 16:24:18
Failed to connect to the data and trade server. | 2014-08-07 16:24:18
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:18
Disconnected from IB. | 2014-08-07 16:24:18
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:18
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:23
Socket (952) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:24
Socket (952) - Shutdown and closed. | 2014-08-07 16:24:24
Failed to connect to the data and trade server. | 2014-08-07 16:24:24
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:24
Disconnected from IB. | 2014-08-07 16:24:24
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:29
Socket (1184) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:30
Socket (1184) - Shutdown and closed. | 2014-08-07 16:24:30
Failed to connect to the data and trade server. | 2014-08-07 16:24:30
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:30
Disconnected from IB. | 2014-08-07 16:24:30
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:30
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:35
Socket (956) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:36
Socket (956) - Shutdown and closed. | 2014-08-07 16:24:36
Failed to connect to the data and trade server. | 2014-08-07 16:24:36
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:36
Disconnected from IB. | 2014-08-07 16:24:36
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:36
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:41
Socket (1184) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:42
Socket (1184) - Shutdown and closed. | 2014-08-07 16:24:42
Failed to connect to the data and trade server. | 2014-08-07 16:24:42
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:42
Disconnected from IB. | 2014-08-07 16:24:42
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:42
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:47
Socket (956) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:48
Socket (956) - Shutdown and closed. | 2014-08-07 16:24:48
Failed to connect to the data and trade server. | 2014-08-07 16:24:48
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:48
Disconnected from IB. | 2014-08-07 16:24:48
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:53
Socket (1184) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:24:54
Socket (1184) - Shutdown and closed. | 2014-08-07 16:24:54
Failed to connect to the data and trade server. | 2014-08-07 16:24:54
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:24:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:24:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:24:54
Disconnected from IB. | 2014-08-07 16:24:54
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:24:54
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:24:59
Socket (1996) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:00
Socket (1996) - Shutdown and closed. | 2014-08-07 16:25:00
Failed to connect to the data and trade server. | 2014-08-07 16:25:00
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:00
Disconnected from IB. | 2014-08-07 16:25:00
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:00
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:05
Socket (1060) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:06
Socket (1060) - Shutdown and closed. | 2014-08-07 16:25:06
Failed to connect to the data and trade server. | 2014-08-07 16:25:06
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:07
Disconnected from IB. | 2014-08-07 16:25:07
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:07
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:12
Socket (1248) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:13
Socket (1248) - Shutdown and closed. | 2014-08-07 16:25:13
Failed to connect to the data and trade server. | 2014-08-07 16:25:13
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:13
Disconnected from IB. | 2014-08-07 16:25:13
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:13
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:18
Socket (1208) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:19
Socket (1208) - Shutdown and closed. | 2014-08-07 16:25:19
Failed to connect to the data and trade server. | 2014-08-07 16:25:19
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:19
Disconnected from IB. | 2014-08-07 16:25:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:19
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:24
Socket (1248) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:25
Socket (1248) - Shutdown and closed. | 2014-08-07 16:25:25
Failed to connect to the data and trade server. | 2014-08-07 16:25:25
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:25
Disconnected from IB. | 2014-08-07 16:25:25
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:25
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:30
Socket (1208) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:31
Socket (1208) - Shutdown and closed. | 2014-08-07 16:25:31
Failed to connect to the data and trade server. | 2014-08-07 16:25:31
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:31
Disconnected from IB. | 2014-08-07 16:25:31
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:31
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:36
Socket (1248) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:37
Socket (1248) - Shutdown and closed. | 2014-08-07 16:25:37
Failed to connect to the data and trade server. | 2014-08-07 16:25:37
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:37
Disconnected from IB. | 2014-08-07 16:25:37
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:37
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:42
Socket (1052) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:43
Socket (1052) - Shutdown and closed. | 2014-08-07 16:25:43
Failed to connect to the data and trade server. | 2014-08-07 16:25:43
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:43
Disconnected from IB. | 2014-08-07 16:25:43
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:43
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:48
Socket (1216) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-07 16:25:49
Socket (1216) - Shutdown and closed. | 2014-08-07 16:25:49
Failed to connect to the data and trade server. | 2014-08-07 16:25:49
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-07 16:25:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-07 16:25:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-07 16:25:49
Disconnected from IB. | 2014-08-07 16:25:49
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-07 16:25:49
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-07 16:25:54
[2014-08-07 23:04:21]
Is Interactive Brokers Trader Workstation running?
We want you to change the port number explained at step 22 here:
http://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions
Step 22 is very thorough. By following those directions, you will most definitely get a connection. There must be some step you are missing.
[2014-08-07 23:34:57]
User53196 - Posts: 13
this may be the problem. The API is disabled. Unfortunately the boxes are greyed out and I cannot enable it. any ideas or do I have to go to interactive brokers?
[2014-08-08 00:07:39]
Interactive Brokers did a new "build" , whatever that is, that I had to download. Problem fixed. Sorry for your trouble. I don't know how one is supposed to know this stuff. anyways thanks
[2014-08-08 00:27:17]
You would not know and we would not know either. If there is some problem with the API being disabled in the TWS without any way of enabling it , then Interactive Brokers would need to help with this.
Date Time Of Last Edit: 2014-08-08 00:28:49
