Date/Time: Mon, 25 Nov 2024 13:50:08 +0000
Why does my footprint chartbook look like this?
View Count: 275
[2024-03-03 01:34:55] |
Sivle - Posts: 53 |
I am new to futures trading and i i bought a footprint chartbook from a guy online. When i load it up in my sierrachartbook i cant see nothing, Maybe its because the market is closed? i also use delayed data because i bought service package 11. I have a pic. |
footprint chart.png / V - Attached On 2024-03-03 01:33:15 UTC - Size: 58.42 KB - 77 views Attachment Deleted. |
[2024-03-03 01:53:48] |
ForgivingComputers.com - Posts: 960 |
You are looking at very zoomed-in prices. Right-Click on the Vertical Scale and select Interactive Scale Range. Then you can drag the scale up and down to change the size of the bars. |
[2024-03-03 01:58:46] |
Sierra_Chart Engineering - Posts: 17172 |
Refer to: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. And then: Numbers Bars: Scaling a Numbers Bars Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
