Date/Time: Mon, 25 Nov 2024 12:46:41 +0000
[User Discussion] - Data that comes with sierra subscribtion
View Count: 215
[2024-03-02 23:19:17]
User134344 - Posts: 24
Can I use data that comes with sierra subscribtion like market internals, fx, cfd, crypro, not sure if theres also sectors or something else, when I ll use rithmic and have switched off that sierra thing in data settings or it needs to be on or it ll not work if I ll not be on sc all data?
[2024-03-04 14:31:00]
If you turn off the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds", then you will not have access to all the data that we have make available. There are also other restrictions when you are connected to a trading service in general.
The best option is to install a second Sierra Chart and have the "Current Selected Service" set to "SC Data - All Services". This will allow you to get the data we have available in that installation while the other one gets the data from Rithmic. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
