Date/Time: Mon, 25 Nov 2024 13:50:08 +0000
spread sheet upside down
View Count: 195
[2024-03-02 18:35:48]
User411320 - Posts: 289
hello, I created a study and while the results are correct, they're upside down. how can I fix this? thanks
imageScreenshot 2024-03-02 133335.png / V - Attached On 2024-03-02 18:35:35 UTC - Size: 7.94 KB - 52 views
[2024-03-02 19:33:50]
Sierra_Chart Engineering - Posts: 17172
You need to change the spreadsheet formula to get the result that you require.
[2024-03-02 20:49:35]
=LN(AA4/AA3)
=AVERAGE(L3:L449)
=STDEV.S(L3:L449)
=STANDARDIZE(L3,$M$3,$N$3)
these are my formulas, which would it be?
[2024-03-02 21:13:43]
nevermind I figured it out
