Date/Time: Mon, 25 Nov 2024 13:44:29 +0000
Control bar button for trading setups
View Count: 255
[2024-03-02 16:52:25]
User440951 - Posts: 50
I have a problem that I can't resolve. I'm trying to add buttons to the control bar with my different configurations saved in the exchange window but I can't do it.
I followed the following instructions: Control Bar: Control Bar Trade Window Configuration Buttons
But when I click on customize, the window that opens does not show me the saved configurations but "Trade Window Configuration (List)"
I am attaching the capture.
Could anyone help me resolve the issue?
Thank you so much
Date Time Of Last Edit: 2024-03-02 16:54:50
imageCapture Trade window configuration.PNG / V - Attached On 2024-03-02 16:52:04 UTC - Size: 71.18 KB - 69 views
[2024-03-04 14:17:13]
You need to select the blank area under the "Value" header next to the "Trade Window Configuration (List)" item. This will give you the list of available configurations to select from. Refer to the following:
Settings Windows Interface: Selection Specific Options (Working with Sierra Chart Windows)
