Date/Time: Wed, 27 Nov 2024 06:35:33 +0000
[User Discussion] - How to create chart summing summing data(e.g. volume/ticks) from two different symbols
View Count: 1030
[2014-08-07 00:34:58]
User27189 - Posts: 26
Is there a way to create a simple bar chart which displays the sum (per bar interval)by combining, for instance, volume or ticks, from two different symbols or especially from two indices?? Thank you.
[2014-08-08 05:23:17]
I'll re-ask the question in a more specific form. Can I create a simple bar chart of NTick-NYSE+NTick-Nasdaq? Thank you.
[2014-08-09 05:04:41]
vegasfoster - Posts: 444
Try Sum Charts from List study.
[2014-08-09 20:49:55]
Thank you "vegasfoster". That does it. Thank you.
Date Time Of Last Edit: 2014-08-09 21:37:30
