Date/Time: Mon, 25 Nov 2024 13:52:15 +0000
Discrepancies in Moving Average values between SC Moving Averages and other platforms
View Count: 178
[2024-03-01 15:52:32]
User566250 - Posts: 37
I was wondering if there is a way to fix the discrepancies in values between SC Moving Averages and other platforms (TradingView/TradeStation) Where they seem to be in agreement.
I have made sure of the following:
1- Enough data is loaded for the chart type: 1Min-5Min-15Min and 60Min for example
2- Session times are a match between platforms
Attached are snapshots on a 5Min chart for 20 XMA where you can see the areas that do not match.
Thank you
imageSC3-1-24.JPG / V - Attached On 2024-03-01 15:48:46 UTC - Size: 139.72 KB - 57 views
imageTradingView3-1-24.JPG / V - Attached On 2024-03-01 15:50:54 UTC - Size: 46.54 KB - 63 views
[2024-03-01 16:19:31]
We supply the exact math we use in our studies along with a Spreadsheet that shows a manual calculation in comparison to the data.
We do not look into differences between our system and other systems.
If there are discrepancies between what we have and another system then you would need to go through how each system does their calculations and determine why there is a difference.
[2024-03-01 16:51:53]
Sierra_Chart Engineering - Posts: 17172
You need to look at differences in the chart bars between the charts.
Also refer to:
Chart Studies: Resolving Study Differences
Also refer to the information here about exponential moving averages:
Moving Average - Exponential
Date Time Of Last Edit: 2024-03-01 16:54:28
