Date/Time: Mon, 25 Nov 2024 13:18:41 +0000
Title Bar Name in the SSW
View Count: 220
[2024-03-01 10:25:06] |
sampater - Posts: 244 |
Sierra Chart Engineering, In the documentation regarding the Title Bar Name it says: The name of the chart as displayed in the Study Summary window will include this text.
But this Title Bar Name does not display in the Symbol column in the Study Summary Window, even if the Use Title Bar Name as Tab Label option is enabled. |
[2024-03-01 16:09:35] |
It is not in the "Symbol" column that that this shows - it is in the "Chart" column. We just verified that this is working properly.
[2024-03-01 18:21:29] |
That's right. Another question about customize Quote Board Fields in the SSW. Is it possible coloring the OpenPositionP/L background depending on the profit/loss? |
[2024-03-01 19:20:45] |
There is not a way to color that specific item. But, you can add the "Trading: Daily Profit/Loss" and set the Subgraph for that to color based on +/- and then the color of that item in the Study Summary Window will be colored based on +/-. Unfortunately, there is not an equivalent study for the Position P/L that has the data in the subgraph that can be used in this same way. You could always create one, if you wanted to do this. Refer to the following: Automated Trading From an Advanced Custom Study: Getting Order Information For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
