Date/Time: Mon, 25 Nov 2024 12:40:07 +0000
Alerts for platform update
View Count: 192
[2024-03-01 04:40:21]
tommartin321 - Posts: 74
Over the years I’ve noticed the only time I’ve had any sort of performance issue is when my platform is not currently up to date. And the only method I’m aware of is to manually check the version update page.
Is there a way to create an alert telling me a platform update is available?
Thanks,
Tom
[2024-03-01 05:00:21]
Sierra_Chart Engineering - Posts: 17172
Sometimes we put out update notices which you will see when you restart Sierra Chart and then you will get the System Notification Window indicating there is a new version available.
If you have performance issues, refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
An update is not necessarily going to help. Usually not.
Date Time Of Last Edit: 2024-03-01 05:00:43
