Date/Time: Mon, 25 Nov 2024 12:43:20 +0000
[Programming Help] - CQG login error
View Count: 228
[2024-03-01 00:43:28] |
User652709 - Posts: 1 |
To whom it may concern, Attached herewith please find the picture for your reference. What is my user name and password for the CQG? Why always show this message to me? Kind regards, Simon |
2024-03-01 001.JPG / V - Attached On 2024-03-01 00:42:16 UTC - Size: 42.66 KB - 61 views Attachment Deleted. |
[2024-03-01 01:13:29] |
Sierra_Chart Engineering - Posts: 17172 |
This message is from CQG. Contact your broker for help with resolving this. More information at 5: CQG Trading Platform Service: Common Error Messages In the meantime: To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
