Date/Time: Wed, 27 Nov 2024 06:32:17 +0000
Need help with Numbers Bars Study
View Count: 910
[2014-08-06 21:35:15] |
User78286 - Posts: 15 |
I added Numbers Bars Study to a chart, but the study would not display anything, all I get is blank screen. I just used the default setting without making any change, the chart has no other studies, just a plain candle chart, 1 min, with Numbers Bars Study on it. Please help |
SNAG-8-6-2014 5.33.08 PM.jpg / V - Attached On 2014-08-06 21:34:40 UTC - Size: 105.37 KB - 340 views |
[2014-08-06 23:58:49] |
The Numbers Bars study requires Sierra Chart service package 5. You are on Sierra Chart service package 3. You can contact your broker to be put on package 5 or get a direct Sierra Chart account: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
