Date/Time: Mon, 25 Nov 2024 12:52:42 +0000
Connecting sierrachart with ironbeam
View Count: 513
[2024-02-29 21:18:30] |
Sivle - Posts: 53 |
I have an account with ironbeam and i want to connect my sierrachart with them. But they say that I need to have 500 usd or more in my account. Money is not a problem but I think its fishy. I mean ironbeam offers you to use sierrachart platform but to change the plattform will "cost" or you will need to have at last 500 usd. How hard can it be to connect your ironbeam account with sierrachart ? |
[2024-02-29 21:22:24] |
Sivle - Posts: 53 |
They say they do this because its for professionals? I also have an IBKR account and I think you can trade futures and use teton order routing service but the margins is higher. |
[2024-02-29 23:05:57] |
Sierra_Chart Engineering - Posts: 17172 |
These questions are not for Sierra Chart. Brokers are their own independent entities, separate from Sierra Chart. We have no control over them. The only thing we can recommend is look at Stage 5 for a broker. They are one of the listed brokers in the setup instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-29 23:06:19
[2024-02-29 23:57:08] |
ertrader - Posts: 672 |
I'm using Ironbeam with Teton and having no issues. Yes, you do have to have a minimum account size but I started with Teton so had no change fees. I simply told them to set up Teton for me...no issues at all and connections are very stable. I also use Stage 5 with no issues.
Date Time Of Last Edit: 2024-02-29 23:58:07
[2024-03-01 13:50:05] |
Sivle - Posts: 53 |
How much is the total cost for buying and selling 1 contract. Going in and out of a position. If you trade micro e mini m s&p500 and e mini s&p500. ? Considering all the exhange fees etc. And that you are new.
[2024-03-01 16:02:55] |
This is a broker question. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
