Date/Time: Wed, 27 Nov 2024 06:26:37 +0000
CQG FIX connection: "The brand of client is not allowed"
View Count: 1648
[2014-08-06 19:02:37]
bluecrow - Posts: 2
Dear Support,
I'm unable to connect using my CQG logon details despite following the instructions very carefully:
http://www.sierrachart.com/index.php?l=doc/CQGTrading.php
Below follows the error message:
_______________________________________________________________
CQG Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2014-08-06 14:52:40
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2014-08-06 14:52:40
socket (1188) | Connected. | 2014-08-06 14:52:40
CQG Trading FIX: Sending the Logon message. | 2014-08-06 14:52:40
CQG Trading FIX: Received a Logout message. Text = The brand of client is not allowed | 2014-08-06 14:52:40
CQG Trading FIX: Sending a Logout message. Text = Received Logout message. | 2014-08-06 14:52:40
socket (1188) | Shutdown and closed. | 2014-08-06 14:52:40
CQG Trading FIX: Logged out and disconnected. | 2014-08-06 14:52:40
CQG Trading FIX: Disconnected. | 2014-08-06 14:52:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-06 14:52:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-06 14:52:40
CQG Trading | Disconnected. | 2014-08-06 14:52:40
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-06 14:52:40
File >> Disconnect selected. | 2014-08-06 14:52:42
CQG Trading | Disconnected. | 2014-08-06 14:52:42
Is there something I've missed?
Many thanks,
[2014-08-06 19:10:18]
You need to contact your broker for help with this. Let them know you are getting this message:
Only your broker can help with this.
[2014-08-06 21:26:31]
bluecrow - Posts: 2
Thanks, the connection issue is now resolved.
