Date/Time: Wed, 27 Nov 2024 06:33:30 +0000
[User Discussion] - Renko Alert
View Count: 1647
[2014-08-06 18:25:44] |
infpz - Posts: 826 |
Is it possible to create an alert for when a renko chart changes from green to red or vice versa? Since renko is a bar type and not a study, I was not sure if this could be done. -PZ |
[2014-08-06 18:36:22] |
User021827 - Posts: 174 |
I think there is a renko study which would enable you to do it with a spreadsheet alert. It may be under custom studies. |
[2014-08-07 00:06:13] |
Yes. This can be done by setting the alert through on the chart itself: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#EnterAlertOnMainPriceGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-07 00:06:43
[2014-08-07 11:51:23] |
I suppose this would involve SG22 as indicated on that page. If anyone has any suggestions on what operator to use, please post. Thanks, PZ Date Time Of Last Edit: 2014-08-07 11:55:46
[2014-08-07 12:35:04] |
crazybears - Posts: 314 |
Hi Infpz silly question i know but do you want that alert at close of the bar ? what type of alert would you like , chart background , sound ,arrow ... ? |
[2014-08-07 12:46:26] |
Crazybears, Just a simple audio alert. I can figure that part out, I am puzzled as to how to format the alert. Thanks for asking! PZ |
[2014-08-07 12:53:08] |
TRY ID0.SG21 >ID0.SG22 OPEN > CLOSE ID0.SG21 < ID0.SG22 CLOSE < OPEN |
[2014-08-07 13:08:48] |
So something like this? =OR(ID0.SG21>ID0.SG22,ID0.SG21<ID0.SG22) |
[2014-08-07 14:39:31] |
yes , later i can try to write a code with ASCIL
