Date/Time: Mon, 25 Nov 2024 12:56:20 +0000
Time and date using crosshair is appearing black with new version 2600 and above
View Count: 365
[2024-02-29 00:16:45] |
User423974 - Posts: 18 |
Hello, When using the crosshair to check the time and date on the buttom of the chart or price, it appears black with no info visible(date, time & price) this happened after the sw update to 2600 and above, this is the case for all chart types, TPO , daily , weekly etc.. Thanks Date Time Of Last Edit: 2024-02-29 00:56:56
[2024-02-29 16:01:40] |
There is a new setting for the color of the text in the price and time boxes which is set to black by default. You need to change this color to what you want. Refer to the following: Graphics Settings: Chart Values: Price and Time Boxes Text Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-29 23:13:25] |
Sierra_Chart Engineering - Posts: 17172 |
Instructions to open the Graphics Settings window: Graphics Settings: Introduction Also refer to the prior post. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-04 01:09:22] |
Hi, I have uploaded an image showing what i mean, values are masked in black and not visible as in the picture(date time and price) using crosshair, and its the same across all my charts, sorry couldnt find any info solving this https://www.sierrachart.com/image.php?Image=1709515203339.png Thanks Date Time Of Last Edit: 2024-03-04 01:21:40
Private File |
[2024-03-04 15:35:22] |
Refer to our answers above. There is a new setting for the text color in those boxes and you need to change it.
