Date/Time: Sun, 24 Nov 2024 16:52:25 +0000
s_UseTool Tool - Tool.Clear() does not clear Tool.Text
View Count: 396
[2024-02-28 22:59:47]
User719512 - Posts: 263
Hi Sierra Chart Engineering,
See this issue for more context and repro.
Issue with UseTool - PLEASE HELP
Tool.Clear() should also init/reset/clear the Tool.Text property.
[2024-02-29 22:37:39]
Sierra_Chart Engineering - Posts: 17156
We are checking on this.
[2024-03-01 02:43:43]
Verified fixed in v2605 and see the fix in scstructures.h line 701 as well.
[2024-05-10 15:06:04]
User844411 - Posts: 3
still the same problem in 2634 ?
[2024-05-10 15:25:47]
There should not be this problem any longer.
[2024-05-10 18:09:17]
s_UseTool Draw;
  Draw.LineStyle = LINESTYLE_SOLID;
  //Draw.LineNumber = 2;
  Draw.DrawingType = DRAWING_HORIZONTALLINE;
  Draw.LineWidth = 2;
  Draw.BeginValue = sc.Close[sc.IndexOfLastVisibleBar];
  Draw.Color = COLOR_GREEN;
  sc.UseTool(Draw);
at the LineNumber is problem.. if you dont define it, green line stay at graph
[2024-05-10 18:09:28]
but anyway thank you
