Date/Time: Mon, 25 Nov 2024 13:18:35 +0000
inside print DOM
View Count: 383
[2024-02-28 22:24:28] |
User770314 - Posts: 4 |
Hello What is the setting to have the inside print in the DOM ? to have the traded contracts, not the depth. Thank you for your help |
[2024-02-28 22:26:03] |
There is the "Current Bid/Ask" and the "Recent Bid/Ask" volume columns available. Refer to the following: Global Trade Settings Windows: Current Traded Bid Volume - Left/Center/Right Aligned Global Trade Settings Windows: Recent Bid Volume - Left/Center/Right Aligned If you are looking for something else, then please give us more information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
