Date/Time: Mon, 25 Nov 2024 13:26:09 +0000
Night sessions
View Count: 194
[2024-02-28 19:12:39]
arruga - Posts: 253
How can I set up by default using the night session (YES), to all my futures charts?
[2024-02-28 20:44:58]
The only way to do this is to edit the Symbol Settings for those futures that you track and make sure the settings for the Session Times are set the way you want them to be. Then when you open a chart for one of those symbols, you will get the times set as you want. Refer to the following:
Global Symbol Settings: Instructions
