Date/Time: Mon, 25 Nov 2024 13:50:52 +0000
renko bar data
View Count: 199
[2024-02-28 15:47:38] |
User411320 - Posts: 289 |
Hello, Please correct me if I'm wrong but it seems the bars are my chart are larger this week compared to last. also the z-score levels also changed as you can see in the pic. Please advise what this means ? I didn't change anything , changes automatically as you scroll. |
Screenshot 2024-02-28 104455.png / V - Attached On 2024-02-28 15:47:22 UTC - Size: 53.73 KB - 56 views Screenshot 2024-02-28 104405.png / V - Attached On 2024-02-28 15:47:29 UTC - Size: 57.22 KB - 47 views |
[2024-02-28 20:30:39] |
What you are seeing is just a scaling issue. When using Automatic scaling, the size of the bars will change as the system is trying to keep the bars within view that you are scrolling to. If you do not want the above to occur, then change your scaling to "Constant Range", as this will keep a constant range of the prices within view, which will keep all the bars the same. Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) Chart Scale and Scale Adjusting: Constant Range (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-28 23:12:31] |
thanks
