Date/Time: Mon, 25 Nov 2024 13:40:09 +0000
Anchored VWAP + bands
View Count: 422
[2024-02-28 15:24:28]
User499894 - Posts: 45
Hi, I use the VbP study to display an Anchored VWAP; via the subgraphs section I am able to display the +2/-2 Std deviations bands of the VWAP, how can I display the +3/-3 Std.Dev. bands?
[2024-02-28 20:16:15]
The first thing to be aware of is that the "Mean Price +/- Std. Dev." is not the VWAP +/- Std. Dev. The Mean price is calculated separately and can be viewed in the Chart Values for Tools window - as the "Trade Weighted Mean Price".
In general, the answer to the question of how to get a 3 * Std. Dev. is to take the difference between the "Mean Price + Std Dev" and the "Mean Price + 2 * Std Dev" and then add difference to the "Mean Price + 2 * Std Dev" to get the "Mean Price + 3 * Std Dev" (and the opposite for finding the "Mean Price - 3 * Std Dev").
[2024-02-28 21:03:03]
User719512 - Posts: 264
If using VbP for Anchored VWAP or adding the additional formulas like above is not to your liking, you might want to look at a user contributed study called ECIVwapV1.5, or a study from OFL that is free and also supports drag/drop, and up to 4 StdDev bands along with other settings. That is at https://orderflowlabs.com/pages/ofl-freemium. So there are a few solutions depending on your needs.
Date Time Of Last Edit: 2024-02-28 21:03:59
imageAnchored_VWAP.png / V - Attached On 2024-02-28 21:03:17 UTC - Size: 33.11 KB - 97 views
