Date/Time: Mon, 25 Nov 2024 10:52:14 +0000
Feature Request
View Count: 249
[2024-02-28 15:22:27] |
User566250 - Posts: 37 |
Hello, I was wondering if I can request keyboard shortcuts or a button panel that would accomplish the following for entry. The button panel can sit in the open space below the current Main tab panel. -Buy the Previous candle's High Or Close Or Open or Low: (Each being a separate function) and the ability to add +/- offset in ticks for each ex. Buy a tick above last Close. Probably needs 4 buttons or shortcuts Not including the offset feature for each -Sell the Previous candle's High Or Close or Open or Low: (Each item is a separate function) and the ability to add +/- offset in ticks for each ex. Sell a tick below last High. Probably needs 4 buttons or shortcuts Not including the offset feature for each Thank you for your consideration |
[2024-02-28 19:16:36] |
masilver - Posts: 22 |
This can be accomplished using a study and the study buttons. Attached is my custom button bar doing something similar. The first three buttons buy and short similar to what you are suggesting. The first setups up two brackets. To change the number of points, however, I have to edit the study settings. It would be nice to have the ability to add dropdown boxes and number incrementors to the button bar. |
Screenshot 2024-02-28 141338.png / V - Attached On 2024-02-28 19:14:38 UTC - Size: 17.71 KB - 63 views |
[2024-03-07 16:45:14] |
Thank you for your response. I wish I was able to program with SC to accomplish this. Unfortunately, I do not have that talent and my previous attempts despite reviewing the documentation on how to do this have resulted in more confusion than anything else.
