Date/Time: Wed, 27 Nov 2024 06:53:17 +0000
ACSIL force recalculation
View Count: 1486
[2014-08-06 15:24:09] |
Herb - Posts: 9 |
In ACSIL, I would like to force a full recalculation of the chart at some point. Is this possible? Thanks. |
[2014-08-06 17:57:55] |
Set sc.FlagFullRecalculate to 1. It will do a recalculate on the next update.
[2014-08-07 08:52:01] |
sampater - Posts: 244 |
Thank you for this feature. Marek |
