Date/Time: Mon, 25 Nov 2024 14:55:42 +0000
[User Discussion] - How can I reduce the size of the numbers in the footprint chart?
View Count: 262
[2024-02-28 09:09:32]
User417891 - Posts: 2
I red the Thread "reduce the size of the footprint numbers" started by User 488910, and the answer from John SC-Support Posts: 29453, but it does not work.
I set chart >> Graphics Settings-Chart, and then I selected in the Fonts tab the Chart Text item and pressed the Select button.
Next I changed the size from 5 to 3, but in the Chart only the size of the numbers on the right scale were reduced.
Please can you tell me, how I can reduce the size of the numbers in the candle sticks of the footprint?
[2024-02-28 15:18:06]
John - SC Support - Posts: 36244
What you are referencing will only work if the Numbers Bars Input for "Font Size Mode" is set to "Same as Chart Font". Otherwise it uses the "Minimum/Maximum Font Size for Automatic Font Size". Refer to the following:
Numbers Bars: Font Size Mode
