Date/Time: Mon, 25 Nov 2024 14:49:41 +0000
Newbie question
View Count: 174
[2024-02-28 06:26:56] |
legotail - Posts: 9 |
Hi. If I spend hours customizing charts and settings on one computer, can I login to SC from a different computer and still have those adjusted settings? Thank you.
[2024-02-28 06:46:44] |
Sierra_Chart Engineering - Posts: 17174 |
Yes, but you do have to manually transfer the settings. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation You do not have to copy any chart data files. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-28 06:47:11
