Date/Time: Mon, 25 Nov 2024 14:26:29 +0000
How to display quantity of diagonal dominant ask/bid % inside a bar?
View Count: 200
[2024-02-28 00:39:21] |
User392433 - Posts: 42 |
When using numbers bars, I want to see the number of diagonal dominant ask/bid% (imbalances) that are in the candle without having to count them all. Is there a way to show this as a number, like 3 sell side imbalances in this candle, or even better, to see it within a range? Thanks |
[2024-02-28 14:57:04] |
John - SC Support - Posts: 36241 |
There is not a way to do this with the Numbers Bars study itself. But you can use the "Volume at Price Threshold Alert V2" that can be setup to alert for imbalances, and you can use 2 copies to get the Bid and Ask diagonal imbalances separately. There is also a "Count of Alerts" subgraph that you can use to get the number of conditions that meet your criteria. Refer to the following: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
