Date/Time: Mon, 25 Nov 2024 15:00:33 +0000
Multiple Sessions Connected to Live Account
View Count: 223
[2024-02-27 18:59:07]
VAProfTrd - Posts: 8
Hi Sierra,
My understanding is that it is possible to have more than one Sierra Chart
Session connected to the same Live Account.
Can you please confirm that my understanding is correct?
Additionally, if the above is true, then is there any limit to the number
of Sierra Chart Sessions connected to the same Live Account?
Thank you.
[2024-02-27 19:00:45]
John - SC Support - Posts: 36244
It depends on what you are referring to as the "Live Account". As different vendors have different rules. Also, it depends on whether you are connecting from instances of Sierra Chart started with "File >> New Instance", or if these are separate installations. Also, there are restrictions on how many different computers you can have Sierra Chart installed on and running simultaneously. And then there are different rules for the data.
Please let us know the particular workflow you are wanting and what services you want to use and we will respond to the specific setup.
[2024-02-28 01:13:29]
Sierra_Chart Engineering - Posts: 17174
What you are asking about is supported with Teton order routing:
Also refer to:
Denali Exchange Data Feed: Connections
