Date/Time: Mon, 25 Nov 2024 14:51:45 +0000
Volume Profile and TPO positioning
View Count: 269
[2024-02-27 16:43:44]
DianaPena - Posts: 33
Is there a way to position the TOP and VbP facing opposite to each other? If you look at the attached image, I'd like to have the VbP to the left of the TPO facing the same way it is there.
I've tried a couple of different things, but no luck.
Thanks!
imageTPO and VbP.png / V - Attached On 2024-02-27 16:43:14 UTC - Size: 58.08 KB - 71 views
[2024-02-27 17:40:09]
John - SC Support - Posts: 36244
There is not a way to do this. You can change the Volume by Price profile to point to the left or right, but it's position will always be to the right of the TPO.
