Date/Time: Mon, 25 Nov 2024 14:43:49 +0000
Upgrading to latest version of Sierra Chart
View Count: 243
[2024-02-27 16:14:31] |
User908493 - Posts: 1 |
Yes, I tried to upgrade to the current version, but it failed. It says: "MD5 for file does not match. File: CrashReporter.exe" "MD5 for file does not match. File: SierraChartStudies_ARM64.dll" "MD5 for file does not match. File: SierraChart_64.exe" "MD5 for file does not match. File: SierraChart_ARM64.exe" |
[2024-02-27 17:31:55] |
John - SC Support - Posts: 36244 |
Something is interfering with the Sierra Chart installation. Use the ZIP installer: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
