Date/Time: Mon, 25 Nov 2024 14:57:49 +0000
Moving to Teton Order Routing
View Count: 299
[2024-02-27 16:13:37]
User290704 - Posts: 12
To update ...
I have decided to trade from sierra and I will keep bookmap as a tool.
Teton seems to be the best option for me.
With Teton, I am a little confuse concerning the margin, the stop losses and the autoliquidation.
I have read that you can help to set that up ?
Thanks,
[2024-02-27 17:31:20]
John - SC Support - Posts: 36244
The margins are controlled by your broker, so you need to ask them about this. The Auto-Liquidation is also something that your broker controls, although not all brokers have support for this yet, so you need to check with them.
What exactly is your question on the Stop-Loss?
[2024-02-28 06:34:56]
When I place an order with take profit and stop loss on my chart, once the order is taken, stop loss and take profit are recorded on the server ?
I am asking in case my computer or my connection shuts down while I am in a trade ...
Concerning teton set up on the sierra plateforme ?
[2024-02-28 15:10:07]
When using the Teton Order Routing service, the Targets and Stops are stored on a server, so you do not need to be connected with your local Sierra Chart software. Refer to the following on this:
Sierra Chart Teton Futures Order Routing: What is Included
