Date/Time: Mon, 25 Nov 2024 13:25:42 +0000
Question on Footprint Chart
View Count: 239
[2024-02-27 15:37:27] |
User760022 - Posts: 8 |
Hello, I am unable to transition into footprint chart. I do have a 2019 MacBook Air and was wondering if that would be the issue. |
Screenshot 2024-02-26 at 10.26.54 PM.png / V - Attached On 2024-02-27 15:37:22 UTC - Size: 233.23 KB - 58 views |
[2024-02-28 18:40:48] |
Sierra_Chart Engineering - Posts: 17172 |
Refer to: Numbers Bars: Scaling a Numbers Bars Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
