Date/Time: Mon, 25 Nov 2024 14:53:34 +0000
Footprint
View Count: 194
[2024-02-27 03:33:34]
User760022 - Posts: 8
I am unable to transition to footprint chart. I do have a MacBook Air 2019 and was wondering if that was causing the issue.
imageScreenshot 2024-02-26 at 10.26.54 PM.png / V - Attached On 2024-02-27 03:33:09 UTC - Size: 233.23 KB - 48 views
[2024-02-27 16:06:13]
John - SC Support - Posts: 36244
What you are seeing is a scaling issue. Refer to the following:
Numbers Bars: Scaling a Numbers Bars Chart
