Date/Time: Mon, 25 Nov 2024 15:01:48 +0000
1 minute candles not visible
View Count: 189
[2024-02-26 22:09:00] |
User183193 - Posts: 5 |
Hello, I want to open the month of March 2021 for GBPJPY parity. Even though I downloaded all the data, daily candles appear, but when I move the chart to 1-minute candles, they do not appear. What's the problem ? I'm sending a screenshot of the problem. |
1 Minute.JPG / V - Attached On 2024-02-26 22:08:49 UTC - Size: 76.01 KB - 43 views |
[2024-02-27 15:44:22] |
Sierra_Chart Engineering - Posts: 17174 |
If you are limiting the chart to data in the year 2021, this means there is not Intraday data for that year. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-27 16:06:16] |
I tried the methods in the url you sent. I've done this before. It was showing 1 minute candles. but now I can't find it. How can I show all 1-minute intraday data for 2020 and 2021? Can you describe it?
[2024-02-27 16:54:36] |
Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
