Date/Time: Mon, 25 Nov 2024 15:02:58 +0000
Sync chart does not work with maximized windows
View Count: 185
[2024-02-26 20:49:55] |
n_wilson - Posts: 2 |
Has the behaviour of the crosshair changed? Up to now I could use the crosshair in one chart and the other charts were synced to its position. All chart-windows are maximized (only one in view at a time), global cursor and sync charts are ON. I used this function for years. Now it seems to work only when the windows are not maximized. With maximized windows the other charts do not move. Is that intended? Has that changed? Or - probably - am I missing something? Thank you. Date Time Of Last Edit: 2024-02-26 22:14:34
[2024-02-26 21:13:27] |
Sierra_Chart Engineering - Posts: 17174 |
We will look into this. Are these charts part of the main Sierra Chart window? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-26 21:49:17] |
Yes, they are. https://www.sierrachart.com/image.php?Image=1708984344840.png Date Time Of Last Edit: 2024-02-26 21:53:20
[2024-02-26 22:30:55] |
This will be resolved in the next release.
